2006-07-15
12:21 AM
- last edited
3 weeks ago
Aruzhan Ilaikova
2006-07-15 12:28 AM
2006-07-15 12:44 AM
2006-07-15 06:56 AM
2006-07-15 08:57 AM
2006-07-15 03:55 PM
Adding to the confusion, I discovered a layer called " ArchiCAD - master only" which I can delete but will be recreated when switching to or from layout. Why, I don't know.We have the same thing happening for every PLN project.
2006-07-16 03:23 AM
Link wrote:. . . and until that day my own view is to place
Hopefully one day....
2006-07-16 09:27 AM
~/archiben wrote:I agree. Keep it simple. Layouts are one at a time for output. Just because you can do something (like mess around with layer combinations in layouts) doesn't mean you should.
. . .my own view is to placeeverythingon a layout on the archicad layer and try to use intelligent objects in title blocks rather than getting fancy with layer combinations.
...until graphisoft actually give us two totally independent environmentsLike ArchiCAD and PlotMaker? Is that the next big advance?
2006-07-16 11:26 PM
I agree. Keep it simple. Layouts are one at a time for output. Just because you can do something (like mess around with layer combinations in layouts) doesn't mean you should.That's not like you to think so far inside the box Matthew? Maybe publishing your entire documentation set from one sheet is a stretch, but how about using different layer combos for different options? Different areas? Different rotations? It's not there yet, but with some imagination it could be?
Like ArchiCAD and PlotMaker? Is that the next big advance?Now
2006-07-17 12:29 AM
Matthew wrote:aw! you know what i mean! link's made a list of the settings and attributes (here) that both are and aren't 'environment' dependent. it's sorting which on the list...until graphisoft actually give us two totally independent environmentsLike ArchiCAD and PlotMaker? Is that the next big advance?![]()
