2015-02-15 03:03 AM - last edited on 2023-05-19 03:55 PM by Gordana Radonic
2015-02-15 01:11 PM
2015-02-16 03:03 PM
psmith_stz wrote:This is not possible currently. There is no setting to format the numbering of Revisions. So you would have to change the Revision IDs on the Sheet Index. Or, another method is to select all Layouts in the Layout Book, go to the Layout Settings Dialog and modify the Revision ID of all those selected Layouts in one step.
1. We use letters not numbers for revisions...
Eg.. Revision A, B, C, AA, AB, AC etc
Is there a way so this is setup as the default. It seems that the only way to do this is after you create the first issue for a layout that you manually change the revision id.
I have found out that if I create a sheet index with the revision ID field listed I can change manually here
2. Creating an issue that does not include EVERY layoutIn the Layout Book, right-click the Book icon at the top and click the Book Settings command. Then go to its Issue History panel.
Out template is setup with all the standard layouts that would be typically used on a project for all the various stages (about 50). When you first start a project you are not issuing all of the drawings - typically only one or two... and this might be the case for some time... but every time you create an issue it includes every drawing that has not yet been issued... Is there a way to stop this and add drawings that have been changed? Or is it best to start the project and issue everything (maybe I have already done this in the template....
3. Change ID prefixIn your Template file simply activate the Change Tool, modify its Change ID field to "01" and save your changes to the file. You don't have to place a Change and delete it. The first time a Change will be place its ID will be the specified "01" value.
I like the idea that the change id is chronological (ie does not change with the drawing revision) but I don't like the 'ch" prefix...
The only way I can work around this is to in the template create a change - rename it 00, then delete the change... The first change some will make will then be 01.
4. Revision history objectCheck this post about an updated Revision History object that is available:
Ideally my revision history object would only show:
- only the current revision
- the changes that relate to the current revision each on a separate line
To achieve this I tried the detailed version, however the number of lines setting seems to be absolute and either limits the number of changes visible on a sheet or shows more revisions. If I use the simple version I only have 3 lines showing - I get only the current revision visible, however the changes are all in wrapped text and comma separated.
2015-02-25 02:41 AM
laszlonagy wrote:I got some info from Graphisoft from the Product Designer of the revision feature that this is actually possible to do.psmith_stz wrote:This is not possible currently. There is no setting to format the numbering of Revisions. So you would have to change the Revision IDs on the Sheet Index. Or, another method is to select all Layouts in the Layout Book, go to the Layout Settings Dialog and modify the Revision ID of all those selected Layouts in one step.
2015-02-25 09:09 AM
2015-02-25 11:20 AM
laszlonagy wrote:Sorry, my bad. Again.
The only thing you will not be able to achieve is for the Revision History object to automatically adjust its number of rows. That is currently not possible to do with this object.
2015-02-25 11:29 AM
DGSketcher wrote:Trick ArchiCAD. Enter a SPACE character for the Revision ID for all Layouts in the first Issue. It will look like there is no Revision ID.
Laszlo, this still doesn't resolve the first issue problem where the convention is to issue without a revision number or letter as the drawing is original and has not been altered. For those who use A, B, etc using the hide first issue option in the revision object doesn't help as it means the first displayed revision will be B. There needs to be a means to set the default for all layouts to A, B, etc that also recognises an original issue has no revision.
Of course we could also look at changing national convention...
2015-02-27 01:06 PM
2015-02-28 05:52 PM
2015-03-11 08:37 PM
