ā2007-01-17
11:16 PM
ā2025-02-07
02:40 PM
Aruzhan Ilaikova
ā2007-01-17 11:42 PM
ā2007-01-18 12:06 AM
ā2007-01-18 01:19 AM
ā2007-01-18 02:02 AM
Sara wrote:In my opinion it is a bug.
A quick query: I have two roofs, one set at 5 degrees, the other at 15. Both of their fill settings are exactly the same and the drawing display options are correct. However, the 5 degree roof hatch appears to scale independently and plots out as a 25% fill. See attachment. Any suggestions would be greatly appreciated.
ā2007-01-18 03:09 PM
Barry wrote:Have you checked to see if this affects output? Fills generally switch to their bitmap version when the screen zoom is to far away to display the vector fill properly (ie. it would go solid from lack of enough pixels). This is generally a screen display effect only and should not print.Sara wrote:In my opinion it is a bug.
I have just recently reported this th GS AUS but have not heard back yet.
It may pay if you and any others report this problem too.
As you zoom in you will find the hatch pattern will revert to exactly what you are after.
As you zoom out the roof gets to a stage where it no longer uses the vectorial fill but switches to use the bitmap fill as set for that particular fill.
To prove this set the bit map pattern for a vertical vectorial fill to be horizontal (i.e. totally different to the vectorial pattern) and use this fill on the roof.
Try it with 3 or 4 different roof pitches.
As you zoom out they will all start to change to the bitmap fill starting with the lowest pitch.
Just a regular polygon with the same fill will be unaffected.
This is only for fills set to "Scale with plan".
Fills that have been set to "Scale independent" seem to be fine - but of coarse they no longer suit all scales.
It is as described by Stuart in his link above - but the other problem with the printing of the 25%, 50% fills is a different one.
ā2007-01-18 06:49 PM
s2art wrote:You should witness my senior blonde days ...
Sorry, I'm having a blonde day*.
*No offence meant to blondes, either natural or otherwise.
ā2007-01-19 01:58 AM
Matthew wrote:Yes I have seen it affect the printed output as well.
ā2010-07-22 10:35 AM
ā2010-07-22 11:24 AM
