2021-06-28
09:25 AM
2023-05-26
02:20 AM
Gordana Radonic
2021-06-28 10:19 AM
2021-06-28 12:03 PM
2021-06-28 02:01 PM
Helm_Arch wrote:
Which means I have no possible solutionI guess it's one more suggestion to send to Graphisoft for their "wish list implementation".
2021-06-28 10:56 PM
2021-11-04 12:41 PM
No you guys 😕 ...this is not what we want to hear 😉😄
We use the Curtain Wall tool to also create shelving, custom block walls & facades and even other element types in some cases.
I came looking for a solution to the same problem to help a client, but understand the display limitations as you outline them here. Thank you at least @Barry Kelly & @Laszlo Nagy for your workaround suggestions.
In all 3 cases you have to create an 3D Axonometric View / get a 2D Elevation View of the curtain wall as a starting point.
I did a quick test and want to suggest the following to further improve this workaround:
This feels like the shortest and easiest to manage workflow. It keeps the drawing a live 3D drawing that updates as the design model is updated + there is no re-work as with the object and 2D Fills & Lines routes. The only aspect that will still be a pain, is to keep checking and aligning the Schedule & 3D Document drawings on the Layout before publishing.
