2024-12-19
03:52 AM
2025-01-02
11:07 PM
Hi everyone,
I'm a bit rusty with Archicad, and I'm encountering an issue that I hope has a simple fix.
Saved View Not Showing on Layout:
Ground Floor View Problem:
Has anyone encountered these issues before, and could you suggest what might be going wrong? Any tips or steps to troubleshoot would be greatly appreciated.
Thanks in advance!
Solved! Go to Solution.
2024-12-19 03:57 AM
What happens if you change the Crop to Frame setting to Fit? Does the View display properly when you open it?
2024-12-19 03:57 AM
2024-12-19 04:20 AM
Absolutely nothing and every time I do ArchiCAD crashes and I send a bug report!
2024-12-19 04:38 AM
So, I decided to recover the file, which I hadn’t done previously, and to my surprise, an empty box appeared where the saved view should have been. This was obviously what I needed! I expanded the edges of the box and brought the view back to the center, and that turned out to be the fix. I initially thought the crashes meant the file wasn’t working or responding, but I was just too quick to give up and worried about messing it up further. So thankyou 🙂
2024-12-19 06:23 AM
If you set the View to use the Internal Origin, the View will not move if you add something that changes it's extents.
