2024-10-30
02:59 PM
- last edited on
2024-10-30
11:44 PM
by
In Archicad only, when I print and save to a pdf, the default file name is "untitled", as opposed to whatever layout or view I'm working in. Other software give a relevant file name.
It's annoying to have to type the name of something other software seems to be able to work with.
Is this a work environment thing I changed by mistake?
2024-11-04 02:14 AM
Use the Publisher.
| AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2024-11-04 02:30 AM
Thanks for the reply, but no.
Not for just a random on the fly print. For example, I'm printing a view of a 3d doc or room int. elevation only, no titleblock. And that only saves to whatever name you've given the publisher set, even if its a single layout.
But seriously. Thanks for bothering to come up with a solution. I was worried my question was unclear.
2024-11-04 04:24 AM - edited 2024-11-04 04:43 AM
Only if you have set it to merge. Publishing individual files uses what ever layout naming convention you have set.
Maybe make a Wish for the default name to match that of the View that you are printing from.
Ling.
ps. When I Save As a PDF, the default name is the file name or the drawing type... ELEV for elevations, *Section Name*, *3D Document Name*, *Schedule Name*, *File Name* for floorplans and 3Ds. Is this an external PDF printer that you are using?
2024-11-14 08:30 PM
Problem solved. Yes, an external pdf printer. I deleted the printer driver(Kyocera) and installed a new one from their website. PDF file is no longer defaulting to "untitled."
