Section Markers (linked in other locations)
Hi There
I have had a wee search around but havent seemed to come across this as yet, I have the Section Markers shown on my floor plans
some running north south and others running east west
when im looking at an east-west Cross section id like to be able to see all the north-south markers that would be visible in thier true correct location and if that marker gets moved on the floor plan its position would update live in the cross section also
I want to be able to customise the markers and their heights etc
It isnt obvious to me from looking anywhere inside the section marker tool
Im also wanting to make sure it is linked correctly in terms of my detail referencing and for opening views later in bimx hyper models which i still havent quite played with too much.
Also along the same vein of what im trying to achieve
While im in Section E for example im trying to place linked markers to other sections: A B & C for example
so I select the Section marker tool and draw on a section with the options 'place linked marker' & 'the first placed drawing of the selected view'
draw it on and position it into place which is fine, and appears to be linked correctly and hasnt created a new viewport... BUT
when I copy all the linked markers i have made in this section E into section F
It creates completely new Sections in the view editor
'A1' 'B1''C1' and then in subsequent sections 'A2' 'B2' 'C2' and so on
WHY!? is it creating new viewpoints when they are selected as linked markers
i then have to go back and relink all the copied markers to their proper location ie Section A (not A1, A2 or A3 etc)
and then go and delete the superfluous views that Archicad has created
It would be good if sections shared the same 'intelligence' of Grid lines
where they can be turned on and off in section mode but obviously lacking the intelligence of taking you to a Cross Section viewpoint.
Am I going to have to go through this same rigmarole of a process to get my section markers on my elevations also?
I tried this but it was working fine for me.
When I copied a Linked Marker and pasted it into another Viewpoint, it did not create new instances of the View int was linked to. So I could not reproduce this issue.
However, the wish part of this post I agree with. You should create a true wish out of this so we can vote on it.
