2024-04-04 01:38 PM - edited 2024-04-06 10:08 AM
I have added a View into a Layout. The Drawing is to show with its own Colors ('Defined by Pen Set'). The View is saved with the Graphic Override option to make all pens black. And yet, the Section lines maintain their own color. Am I missing something?
Basically the whole drawing is showing correctly, all the pen colors are switched to black, as per my GO rule. But the Section lines keep their own color, set from the Plan view. But in Plan view, when I select the particular View (ie with the GO rule enabled) the Section lines show correctly, in black. Just not in Layout.
2024-04-05 10:15 PM
Can you show a few screenshots?
1. How the Source View looks.
2. The View Settings.
3. How it looks on the Layouts.
4. The Drawing Settings of View placed on the Layout.
2024-04-06 10:07 AM - edited 2024-04-06 10:09 AM
Hi Laszlo, thanks for jumping in. Please see below screenshots of both the View source and the Layout screen, with their respective settings.
I have amended the thread title to reflect that it's only the Section Markers that show in the wrong Pen, not the lines themselves. My apologies.
2024-04-06 02:37 PM
That is interesting. Now, if you right -click the Drawing on the Layout and activate the "Open Source View" command, the Source View opens.
Are the Sections still blue now in that opened Source View?
2024-04-06 03:19 PM
Hi again Laszlo, thanks for the reply. I had already done the 'round-trips' between Source (Plan) view and Layout and yes, it shows all black (ie correctly) in Plan view. It's a bug.
I wonder if anyone else can replicate this on their setup. If you use Graphic Overrides to switch Pen color for your section markers, do they show correctly in Layout?
2024-04-06 04:23 PM - edited 2024-04-06 04:23 PM
OK, I will report it to GS HQ as a bug.
By the way, are you on the latest update (27.2.0)?
2024-04-06 04:24 PM - edited 2024-04-06 04:25 PM
PS Yes, I am.
2024-04-08 04:39 AM - edited 2024-04-08 04:42 AM
It is working for me.
Can you show a screen shot of your Graphic Override rule settings?
Maybe you are not overriding the foreground and background pen colours for the fill (drafting fills)?
2024-04-08 08:52 AM
Hi Barry, thanks for your reply. My GO is using a single rule, which turns everything except my DPC and VCL to black:
If I switch the background colour as well, like this:
that results in something different to what I want in Plan view:
My rule, as already configured, works correctly for my needs. But it simply 'misses' the Section Markers in Layout only (works fine in Plan view).
2024-04-08 09:34 AM - edited 2024-04-08 09:36 AM
It seems as soon as you add any 'Pen does not contain' criteria, the section lines lose the GO, but only in the layout.
And only the section line marker (head) the section line still does get overridden.
But in your case the marker seems to be overridden (at least the fill and text) but the section line is not
I don't know why this is the case.
