alexliz
Section marker Pen color is wrong in Layouts
I have added a View into a Layout. The Drawing is to show with its own Colors ('Defined by Pen Set'). The View is saved with the Graphic Override option to make all pens black. And yet, the Section lines maintain their own color. Am I missing something?
Basically the whole drawing is showing correctly, all the pen colors are switched to black, as per my GO rule. But the Section lines keep their own color, set from the Plan view. But in Plan view, when I select the particular View (ie with the GO rule enabled) the Section lines show correctly, in black. Just not in Layout.
Archicad 29.0.2 (3200) INT; macOS Sonoma
12 Replies 12
alexliz
Hi Barry, bit confused - are you saying that you tried to replicate this on your setup and the behavior is different to what I describe?
This was version 27 build 5003.
alexliz
Ah, I see, thanks. Same as on mine.
