Section marker
Llian
Attached is a screen shot showing 2 section markers. How do I remove the nodes shown on the bottom marker so that it is consistent with the one above it? I tried with the palette on ever node but there isn't a remove function. Please help.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
Hi Llian
It looks like the section line at the bottom is broken into several segments: 3 for what I can see.
There is no "magic button" to revert the section line to a simple line, but you can:
  • -Select the Section Line,
    -Then select the hotspot (node) at the end of the first segment, here the Pet Palette will pop up.
    -Select the Move Section/Elevation Line Segment option.
    -Now move the hotspot along the section line over and beyond the section marker Head.
This will make that segment of the section line disappear.
If you repeat this procedure with the other segments you eventually will end up with a single segment Section Line.
I hope this helps.
Regards and have a nice weekend
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
