Sheet Index
dhnguyen
How do I remove some sheet from showing up on the sheet index?
Also, how do I remove the "Published" Category?
Please see attached image
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Click on the top right side of your screen on the Index options
Then add an exclusion criterion about the layout(s) you don't want
And finaly delete the column "Published"
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
dhnguyen
Thank you!
DNguyen
ArchiCAD 18- 25
