2024-11-08
11:02 AM
2024-11-14
01:53 AM
Sheet index - how to create sub headers dividing different sheets? Please see the attached sheet index and example of what I want it to look like. Thank you
Operating system used: Windows 23H2
Solved! Go to Solution.
2024-11-08 12:24 PM
To achieve this:
You'll need to Create Subsets in your Layout Book:
Sort the Index by:
and turn on:
Take into account that in some cases it will be easier to create multiple Indexes instead of trying to get one that is perfect.
another Moderator
2024-11-08 01:07 PM
One option is to create a new property to Layout Info Scheme in Book Settings, eg. "Drawing Type":
Then you can set the drawing type in layouts' settings:
Then it's possible to display the custom layout property in the sheet index and group the items by this value:
2024-11-08
12:19 PM
2024-11-14
02:12 AM
Hi !
You should place those sheets in folders in the layouts view.
I know that the screenshots are in polish, but you will get the idea.
Michał
2024-11-08 12:24 PM
To achieve this:
Sort the Index by:
and turn on:
another Moderator
2024-11-08 01:07 PM
