ELEVATE
Sheet index - how to create sub headers dividing different sheets?
Sheet index - how to create sub headers dividing different sheets?  Please see the attached sheet index and example of what I want it to look like.  Thank you
Operating system used: Windows 23H2
DMD
2 Solutions
Eduardo Rolon
To achieve this:
You'll need to Create Subsets in your Layout Book:
Sort the Index by:
and turn on:
Take into account that in some cases it will be easier to create multiple Indexes instead of trying to get one that is perfect.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
vlahtinen
One option is to create a new property to Layout Info Scheme in Book Settings, eg. "Drawing Type":
Then you can set the drawing type in layouts' settings:
Then it's possible to display the custom layout property in the sheet index and group the items by this value:
Go to post
3 Replies 3
cichy
Hi !
You should place those sheets in folders in the layouts view.
I know that the screenshots are in polish, but you will get the idea.
Michał
Eduardo Rolon
To achieve this:
Sort the Index by:
and turn on:
AC29 US/INT -> AC08
vlahtinen
