2023-11-30 10:21 PM - last edited on 2023-12-01 02:03 AM by Barry Kelly
Some of my layouts in my publisher sets are not publishing. It says it published but when I go to the folder it will not show in the folder.
2023-12-01 02:04 AM - edited 2023-12-01 02:04 AM
Are you publishing as PDF files?
If so, are you merging the pages into a single PDF rather than individual files?
2023-12-01 09:40 AM
Also check you file name length if you are using Windows
This has happened to me before when the filename path exceeded a certain number of characters
2023-12-01 01:12 PM
Yes, they are PDF files. No, I’m not merging them. I need them to be individual files.
2023-12-01 04:46 PM
What exactly do you see in Archicad after you've published the files? Are there all green checkmarks next to all of your published files? Do you see filepaths for all of your files after they are done publishing?
If there are some that show as published in AC and are not in your destination folder, what happens when you right-click on them in the "Publishing..." window in AC and choose "Show in File Explorer"?
