Some commands missing in ArchiCAD 19
I have my keyboard shortcuts configuration in ArchiCAD 16. Some of these commands are missing in ArchiCAD 19.
Especially I assigned F6 button to "Last Section (context menu)" command in ArchiCAD 16, but I can't find it in AC19. "Last Elevation", "Last Layout" and other similar commands also missing.
When I try to assign F7 key to another command, I see that it already assigned (by default) to "Last Layout (context menu)" command, but the command is not in the list of all comands.
Is this a bug?
2 REPLIES 2
Yes, it seems that these commands have disappeared from the list of available commands.
I even went to the Registry Editor and enabled the value of the
HKEY_CURRENT_USER\Software\GRAPHISOFT\ArchiCAD-64\ArchiCAD-64 19.0.0 INT R1\WorkEnvironment\ShowContextMenuTabPage to "1" from "0".
This should make all context menu command appear in the list of all commands in the WE Dialog, and in AC18 it does, but in AC19 it makes no difference.
I will let the guys af GS HQ know about this.
Katalin Borszeki
Hi all,
All (context menu) commands have been changed to hidden commands in AC18.
We added a bug entry so the designers and developers could review this. The fix of this issue (putting back these commands to the Work Environment options) have been classified for ARCHICAD 20.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
