Storey setting
Hi there. I have a problem with the storey settings. For instance, I entered the number for the ground floor level as 10350, but it automatically changed to 3000. It reset to the setting itself.
2 ACCEPTED SOLUTIONS
If you don’t like to add a story below you can change the zero level value to be (10350).
Go to Options menu + Project preferences + Reference Levels + Project Zero (Elevation).
AC 27 INT 5060/WIN 11
I replied to the other post regarding obscured glass, I hope I could understand you correctly.
6 REPLIES 6
Botonis
First change the height of the upper floors.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
Thanks, Botonis for the reply. I am also not able to change the elevation. This option reset to 3000mm.
Hi @Farnoush Pourmoradi,
You can add a story below ground (Basement, Site or Foundation whatever) to have (0) Elev. level then put (10350) in height to next then you’ll find automatically Ground Story Level becomes (10350).
Thanks for replying. Could you please tell me how to make obscure glass in elevation view?
Setup info provided by author
