Storey setting
Hi there. I have a problem with the storey settings. For instance, I entered the number for the ground floor level as 10350, but it automatically changed to 3000. It reset to the setting itself.
2 Solutions
If you don’t like to add a story below you can change the zero level value to be (10350).
Go to Options menu + Project preferences + Reference Levels + Project Zero (Elevation).
AC 29 INT 4006/WIN 11
Go to post
I replied to the other post regarding obscured glass, I hope I could understand you correctly.
Go to post
6 Replies 6
Botonis
Mentor
First change the height of the upper floors.
Thanks, Botonis for the reply. I am also not able to change the elevation. This option reset to 3000mm.
Hi @Farnoush Pourmoradi,
You can add a story below ground (Basement, Site or Foundation whatever) to have (0) Elev. level then put (10350) in height to next then you’ll find automatically Ground Story Level becomes (10350).
Thanks for replying. Could you please tell me how to make obscure glass in elevation view?
