ā2024-04-21
06:17 AM
ā2024-04-24
11:38 AM
Hi there. I have a problem with the storey settings. For instance, I entered the number for the ground floor level as 10350, but it automatically changed to 3000. It reset to the setting itself.
Solved! Go to Solution.
ā2024-04-21 09:08 AM
If you donāt like to add a story below you can change the zero level value to be (10350).
Go to Options menu + Project preferences + Reference Levels + Project Zero (Elevation).
ā2024-04-21 03:25 PM
I replied to the other post regarding obscured glass, I hope I could understand you correctly.
ā2024-04-21 06:28 AM
First change the height of the upper floors.
ā2024-04-21 06:37 AM
Thanks, Botonis for the reply. I am also not able to change the elevation. This option reset to 3000mm.
ā2024-04-21 08:51 AM
You can add a story below ground (Basement, Site or Foundation whatever) to have (0) Elev. level then put (10350) in height to next then youāll find automatically Ground Story Level becomes (10350).
ā2024-04-21 12:29 PM
Thanks for replying. Could you please tell me how to make obscure glass in elevation view?
