Story Layout in View Map v. Layout Book
Zdenko
how do i show story levels in elevation layout book when i can modify and show them in elevation view map. are elevations not the same when discussing elevations? what am i missing? the views have the same darn "exterior elevation" combinations.
Screenshot 2024-06-12 at 1.24.29 PM.pngScreenshot 2024-06-12 at 1.25.04 PM.png
Operating system used: Mac Intel-based Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
Check your elevation settings.
You probably have the storey markers set to 'Display Only'.
You want 'Display & Output'.
Lingwisyer
Guru
They really need to have "Display Only" elements made a different colour...
Setup info provided by author
