‎2006-06-27
05:25 PM
‎2023-05-30
03:24 PM
Rubia Torres
another Moderator
‎2006-10-19 05:20 PM
LINZ wrote:It's a standard convention to lie about your floor levels?
Is it possible to change the story levels standard, so that 0'-0" shows as 100'-0"? This is a standard convention, but i don't see this option.
Help please...
‎2006-10-20 03:45 AM
‎2006-10-20 04:17 AM
‎2006-10-20 04:23 AM
TomWaltz wrote:i take it you're kidding tom?!
‎2006-10-20 04:26 AM
Link wrote:also keep in mind that you will also be altering the storey levels globally throughout the project when you do this!
You can move them by right clicking on them and accessing 'Edit Story Levels' from the context menu. Keep in mind this is a modeless dialog, so don't hit OK until you are finished moving them.
‎2006-10-20 05:06 PM
rengarch wrote:See my wish on this topic: archicad-talk.graphisoft.com/viewtopic.php?t=12256&highlight=
Is there any way to edit the levels text and marker (copy, move, etc) in Section? even when the section/elev. marker is set to Drawing on the plan?
~/archiben wrote:This is what I do.
i model my ground floor/storey 0 at project zero and then use the reference levels in 'Working Units and Levels' to offset all datum height levels down. i want the storey level markers to pick up the values from the reference levels so that i too can show my storey levels at their correct levels relative to the survey datum!~/archiben
