2022-10-25 07:25 PM - last edited on 2023-05-09 05:45 PM by Gordana Radonic
Hi the story levels have randomly stopped showing in my section model views. I am not sure how this happened. Both in the section settings and the story settings the levels are checked.
Solved! Go to Solution.
2022-11-02 10:33 PM
The marker has to be linked to its original section window to be able to be changed back to a source marker.
you change the marker to "unlinked".
you change the marker to "linked" selecting the original section window in the Project Map list
you can now make it source marker again.
sometimes its quicker and easier to add a new section to the model and delete the old one if not too much documentation has been done in the window.
2022-10-26 01:49 AM - edited 2022-10-26 01:51 AM
the section markers are "independent".
did you accidentally delete the section markers?
without the section markers you do not have story levels.
without the section markers all the information is turned into 2d lines and fills(not the 3d Model elements)
If you just wanted to change to 2D lines and fills, you can just change the Status to "Drawing"
2022-10-26 07:46 PM
Thanks , the section markers are still there. And the status is set to auto rebuild model. But could it be because I linked the section marker to a worksheet? But that doesn't explain why the section shows just lines and fills when its set to auto rebuild model.
2022-10-26 11:34 PM - edited 2022-10-27 05:23 AM
In the view you posted
the "Building Section (Independent" text is BOLD
this tells me that is the view you are in when you took the screen grab.
Because its not a "source" view, the level markers will not appear.
How does it know how wide the section cut is? it puts the level markers at the outer edge of the cut.
no source view, no section width, no level markers.
if you add 3D content to your model and this view does not automatically update with the new 3D content then it is not set to "Auto-Rebuild Model".
i don't know how to fix this without changing the marker back to a "Source" section marker, and relink it to the section viewport.
the name will change back to (Auto-Rebuild Model), not (Independent)
Marker Types:
Source Marker
Cuts the 3d Model
Creates a viewport that is a live cut of the 3d model.
the elements in the view are 3D elements like walls and slabs.
Linked Marker
is a reference to another viewport, nothing to do with the model
(useful for detail markers where the same detail is on different parts of a building, you can add a linked marker and the cross reference info will then be the same for detail number/page)
Unlinked Marker
2d symbol not connected to anything
does not create or link to a viewport
if you change the Status to "Drawing", it will change the 3D model information to 2D lines and fills.
you can use the Rebuild from source if the Marker type is a source marker, to regenerate the view from the 3D model (old school like Archicad 6)
if you change Marker Type from "Source" to another sort, the 3D content is converted to 2D lines and fills. the 2D content is no longer linked/connected to the Model.
2022-11-01 09:59 PM
Thanks Allan - the marker is a linked marker so maybe that is why. The section is also 2D lines and not model 3D objects. When I go to change the marker type to source however it is greyed out. I am not sure why I cannot change it
2022-11-02 10:33 PM
2022-11-22 08:34 PM
Thanks! I was able to fix it
