‎2015-09-22
07:53 PM
‎2023-05-30
03:11 PM
Rubia Torres
‎2015-09-24 02:32 AM
‎2015-09-24 02:40 AM
Add Superscript to Dimension TextSo that seems to answer the mystery:
Use theStart/Finish SuperscriptAutotext if you want the Custom text to include superscript text; click this option to insert a caret before the superscript text, and click it again to finish the superscript with a second caret.
Note: If your dimension’s Measured Value already includes a superscript – because you are using Extra Accuracy defined in Options > Project Preferences > Dimensions – then add a space before inserting the Start Superscript caret. Otherwise, the caret itself will appear in the dimension text.
‎2015-09-24 05:50 PM
