2022-08-29 03:00 AM
Hi All,
I would appreciate your wisdom on this subject:
Our office is working on a new school project that consists of 6 buildings. Each building is modelled in an individual .pln file that is accessed through BIMcloud as a Service. All layouts are linked to a "Layout" file which is also stored on BIMcloud as a service. From this file we manage revisions, issues and publish all layouts. We have approx. 1000 drawings across 150 layouts.
The issue we have is that updating all these layouts takes 3+ hours to complete, and as such has to be done overnight. If there is an issue then the updating the process needs to be started again, often during work hours - which we really want to avoid.
Has anyone had a similar issue and if so how did you solve it? Any suggestions would be much appreciated.
Thanks in Advance
Ben
AC23-25
MacOS Big Sur
2022-08-29 09:26 AM
for humungous projects with multiple AC files (teamwork or solo) & it's own Layout File, i would begrudgingly go with the PMK setup & keep an eye out for any Linked Marker issues. it doesn't happen too often, but when it does, it might be an easy fix.
2022-08-29 10:19 AM
I haven't tried .pmk though not sure about how the process works. 😐
2022-08-29 01:11 PM
i haven't done it since v22, so i'm assuming the processes haven't changed. it's pretty easy. it's all set up in the Publisher Sets.
