Template (.TPL file) location and Access on the bimcloud server when starting a new project.
ELEVATE
I am accessing the paid version of the bimcloud/server when working on projects.  The Project File List that contains all the projects also contain the Office Template (.PLN file).  When starting a new project, I have to open the template (.PLN file), save as the "Project name" to my desktop (local machine), then reload to the bimcloud. This is many steps when creating a new project.
Is there a way to have the template (.TPL file) located on the BimCloud where I could create a new project using the template (.TPL file) and then save directly to bimcloud?  Thus eliminating the need to save as to a local machine, then reupload to the bimcloud server?   Thanks
DMD
Mr_Snarl
This is someting that I also wish for. The option to open a new project with a tpl located on the bimcloud.
It could look something like this.
You guys should make a wish for this functionality. Then others can vote on it to show support, and if it gets enough votes within 6 months, it can be submitted to Graphisoft Product Team for consideration.
