Sabrina
Hyperlinks on drawing lists on a PDF
Hi!
Is it possible to hyperlink the drawing or layout ID list, so that it can take you directly to that page after PDFing? Similar to when you click an elevation marker it takes you to the elevation.
This would be great for door / window tags or schedule and it could take you to the door you've selected either on the floor plan or in the schedule on the PDF
3 Replies 3
Marc H
You may want to consider utilizing BIMx as it generates hyperlinks automatically and provides an integrated booster.  Team and clients enjoy the integrated views.  Also, you can upload a custom schedule with all the data so selecting it in the model will provide whatever information you include in that schedule.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
jl_lt
Ace
It would be great. Being able to print a complete pdf set with links inside the document for all reference calls.
Bimx is nice, but sometimes you just need a pdf file.
Davor P
If anyone is still looking for a solution to this, let me know. I was able to build a small app to do exactly this - open pdf, scan through drawings list on index sheet then add link to pages. It can be customized for your use case.
www.vktrs.co
