‎2004-01-15
02:05 PM
‎2025-02-10
04:50 PM
Aruzhan Ilaikova
‎2004-01-15 02:56 PM
‎2004-01-15 06:12 PM
Stephen wrote:Because it will save you creating your own, that's why. It is much more work than just saving a file - the point is, HOW to organize the file.
After starting AC, click on "Create new Project". One option at this point is "Use a Template". I can't find anywhere in the manuals how to create one (or save one). This must be a time saver. Can someone give me a clue? Is Eric Batte's STS something worth purchasing, and if so, why?
Stephen wrote:Oooouch ... where have you been on the old Talk? Sorry if this sounds bad, but I cannot believe that you were, for example, manually saving PMKs and/or DWGs or renderings ?!??!? Who says Publisher is for Web publishing only?
Also, we have never used the publishing feature in AC. In 8.1 (which we just upgraded from 7.0) it seems this is important to learn. We do not post drawings online. Why publish?
Stephen wrote:Steve, please don't get me wrong, but your failure to use the Publisher to the full in 7 makes me think that you were not in contact with other users or were exploring the software as deeply as you could have. I do hope I am wrong, and it is excellent that you realize that you need some training - or, better, conceptual consulting! This is a good place to start
I feel like I have done pretty good with versions 4.55 thru 7.0, but 8.1 has me wishing for some training. Any help is much appreciated.
‎2004-01-16 04:51 AM
Djordje wrote:I'm sorry-how does publishing save time? It sounds like others also manually save PMKs for one reason or another. Teach me-I'm willing to learn.
Steve
‎2004-01-16 07:47 AM
Stephen wrote:Since 7 came out there is no reason, except if you want to save a single PMK, to do it manually.Djordje wrote:I'm sorry-how does publishing save time? It sounds like others also manually save PMKs for one reason or another. Teach me-I'm willing to learn.
Steve
‎2004-01-19 03:03 PM
Djordje wrote:I can see the logic behind navigator. When first starting with it, it just seems a bit tedious. Also, the AC documentation seems very much lacking on this point (ref. manuals and tutorial for 7 and 8.1). My current project will use publisher.
You definitely should ask someone to drop by and show you the logic of Navigator. Maybe AcuWest would be the right place to start? It is best done on person!
‎2004-01-19 07:36 PM
‎2004-01-23 05:05 AM
‎2004-01-25 01:00 AM
‎2004-01-25 07:18 PM
