AC text is linked to "print size" so when you change the scale it will remain legible. So one option in this case is that you have reduced the drawing scale to one that makes Text look huge.
Verify Font size to be 6.25 to 6.5 points or your equivalent in MM.
The implication of this is that if you change the Scale of the drawing then text will start to look bigger but when you print you will not impossible to read texts
If this is a drawing imported from Autocad then you might need to change the way text is handled for this:
- In your Model View first change the scale to match the one in Layout (this should make the texts "fit"). This scale for DWGs is usually 1:1
- Then select All Text (Text tool active and CMD+A) and change them from "Paper Size" to "Model Size".
- Change the scale of the view to the correct one 1:25, 1:50. The text will change proportionally
- Then select All Text (Text tool active and CMD+A) and change them from "ModelPaper Size" to "Paper Size". Text Size should match whatever you use in MS Word or any other "Writing Software".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
