The font is not saved when the drawing is saved in the PDF
Добрый день.
Загрузила на компьютер новый шрифт, все хорошо, все программы этот шрифт видят, архикад тоже видит, но при сохранении чертежа в формат PDF шрифт не сохраняется, изменяется на другой.
Подскажите, как решить эту проблему?
6 Replies 6
Podolsky
Ace
Шрифт пиратский? Я думаю проблема может быть в этом. Если шрифт пиратский - купите оригинальный, я уверен все заработает ОК.
Marianna wrote:
Добрый день.
English language only in this forum I am afraid.
Translation is...
Good afternoon.
Downloaded a new font to the computer, all is well, all the programs see this font, archad also sees, but when you save the drawing in the PDF format, the font is not saved, changes to another.
Tell me how to solve this problem?
Translation...
Is the font pirated? I think that might be the problem. If the font is pirated - buy the original, I'm sure everything will work OK.
Marianna wrote:
Good afternoon.
How are you saving the PDF?
Are you using the Archicad built in PDF convertor (i.e. publishing as PDF), or are you saving with a 3rd party PDF convertor.
If so there may be an option to embed the fonts that is not turned on?
Здравствуйте. Использую встроенный конвертер.
Спасибо.
Спасибо.
Hello. I use a built-in converter.
Thank you.
Please use a Google translator when posting to this forum if your English is not good.
This is an English language only forum and it is not the job of the moderators to translate.
You can easily do that yourself.
I am not sure why if you are 'saving' as PDF through the Publisher, why the font is not showing properly.
However if you are printing directly from the Archicad screen to a PDF converter, check the properties to see if there are any settings to do with the fonts.
