The lines of the windows doesn´t show in section.
FilipStockholm
Hey
I´ve made my walls out of a complex profile, but in my sections the lines of the windows are all white and I can´t change them. See the attached screenshot.
Thanks in advance!
1 REPLY 1
Matteods
Hi why do you need a complex profile? For the roof edge? Model the wall with wall command not a complex profile. It's not recommended to model the entire wall as a complex profile. Then you can model your roof edge as complex profile using the beam tool. In this way the window will be displayed without problem
Greetings,
Matteo.
Setup info provided by author
