FilipStockholm
The lines of the windows doesn´t show in section.
Hey
I´ve made my walls out of a complex profile, but in my sections the lines of the windows are all white and I can´t change them. See the attached screenshot.
Thanks in advance!
1 Reply 1
Matteods
Hi why do you need a complex profile? For the roof edge? Model the wall with wall command not a complex profile. It's not recommended to model the entire wall as a complex profile. Then you can model your roof edge as complex profile using the beam tool. In this way the window will be displayed without problem
Greetings,
Matteo.
