Titleblocks using PMKs
Until now I have used MOD files to populate our office template (eg A1 Design titleblock, A2 Design titleblock, A1 Working titleblock etc).
This method works quite well, it does require several worksheets and views setup.
Just testing the idea of using PMKs instead of mods.
Seems to work really well (using dynamic auto-text, instead of baking).
Before I go any further, can any one comment on what their experience has been using PMKs for titleblocks?
PS a limitation in both workflows is that the revision table appears to need to be located on the actual master, in the file, and doesn't work when in the MOD or PMK.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
dkaramaneas
we use the exact system. As long as those pmk’s are accessible to every file it works amazingly. Been doing it for about 5 years now like that. You have to make sure also any specific fonts are loaded on every computer
