ā2009-05-29
06:41 PM
ā2023-05-23
03:13 AM
Gordana Radonic
ā2009-05-29 09:21 PM
ā2009-05-29 10:18 PM
ā2009-06-01 03:12 PM
Hence wrote:In the Trace Reference Palette it is also possible to filter what TYPE of elements of the Reference should be shown. You can also check if that has the settings you want.
We are having a strange and frustrating problem in my office with one particular file. Views that are used as trace references are not showing up with all the walls or other elements in the view we are referencing them into. (ie: reference floor plan into elevation and walls and column lines do not show up correctly.) I know that the reference uses what layer combination is active, so it is not that the A-wall layer is turned off. Has anybody else had this problem, and if so, where you able to fix it? Thank you.
ā2015-10-01 02:40 AM
