We value your input!
Trace & Reference in Layout
dhnguyen
I'm looking to turn on my Trace and Reference in layout view and having the ability to plot it as well. Where do I go to turn on this setting?
Currently it disappears when I open the layout sheet.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
I may be wrong but to my knowledge this is not possible.
Ransom Ratcliff
Use the Print rather than the Plot command. The Print Dialog has a check box to "Print the Reference." When using the "Save As" command to PDF format, click the Document Options button to see the check box for "Display Reference".
Ransom Ratcliff
RATCLIFF CONSULTING LLC
Charrette Venture Group
ArchiCAD 4.55 - 28
Apple M3 Max + Dell Precision Workstation
