Transparency is applied to the slab in the 3D view, but it is not applied in the document. Is it i
LeeJaeYoung
1.Transparency is applied to the slab in the 3D view, but it is not applied in the document.
Is it impossible?
2. When creating a document, add ! The mark appears, how can I erase it?
AC27 on window 11
Akpocky
There are two ways to solve it.
1.check the surface of transparency. It must be above 80% to show transparent in 3D document.
2.check the 3D document setting make sure that the check box of transparency was ticked.
CPU: INTEL I3-12100 F 3.30GHz
VGA: RTX 3050
RAM:16GB
WINDOW 11 22H2 OS BUILD 22621.1848
Archicad 27 Build 4030
LeeJaeYoung
AC27 on window 11
You are overriding with a transparency of 30%.
You may need a higher value as Akpocky mentioned.
Also is the 3D Document set with the correct Graphic Override?
