2022-04-06 04:11 PM
Hi All
I am relearning Archicad after a long hiatus. It's been going very well and the answers I've needed on this forum and on YouTube have been great. However....
I have a stair and I can not change its renovation status from existing to demolition. What am I doing wrong?
I've created a new stairs on both with both demolition and proposed to test this, but then can't change those either. I'm working in Archicad 22 on a Mac
2022-04-06 04:25 PM
Is the option not available to you?
2022-04-06 04:28 PM
Hi Barry
No, the options are greyed out
2022-04-06 04:44 PM
I very rarely use renovation filters.
What would cause it to be greyed out I wonder?
Is this a teamwork file or a stand alone PLN?
Barry
2022-07-05 08:33 AM
Bumping this up - I'm facing the same issue with some doors.
The renovation status bar in the settings were all greyed out too..
2022-07-05 08:48 AM
As I asked the original poster - Is this a teamwork file or a stand alone PLN?
As a stand-alone PLN I can't think of anything that locks the renovation status.
I don't use teamwork so I can't check if it is a permission thing.
Can you access the Renovation Filter Options dialogue OK and make changes there?
2022-07-05 08:53 AM
Hi Barry,
Thanks for your reply.
The file is on teamwork - but I have reserved the element so it shouldn't be a permission thing. I have been using renovation status and it has been working - just some elements from time to time that I couldn't change or edit the status..
The Reno filter option dialogue also showed greyed too...
2022-07-05 08:55 AM
Is changing it via the Renovation Palette disabled too?
Would appear that changing a single element within an existing stair to new does not change the overall renovation status.... In 22 anyway.
Ling.
2022-07-05 09:01 AM
Hi Ling,
Yeah both palette and settings are greyed out.
I can reserve, delete and create another door on the same wall but all fo them seemed to be greyed out..
2022-07-05 09:43 AM
What's the Renovation Status of the wall?
