Gisele
Unable to change the size of the dimension line's arrows.
Attached are two screenshots showing the dimension line and its settings. It is not on a locked layer; I can change properties such as lineweight but I cannot change the size (or type) of the arrows. Kindly advise.
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
1 Solution
DGSketcher
Legend
You were so close...
The arrow is set under "Marker Type" in your screen shot and the size by "Marker Size" in the settings below...
Go to post
DGSketcher
Legend
