Update issues with plotter
Bob Moore
When I installed the latest Archicad update I lost the ability to plot to my Oce TDS 320 Printer/plotter.
Has anyone else had this issue?
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
4 REPLIES 4
I do not have a plotter but:
Is that AC24 Update 7000?
Bob Moore
No, it's the latest AC 25
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Ah, OK, in that case you should update your signature.
I will report this to Graphisoft.
Bob Moore
Thanks. I did that as soon as I got your reply.
I am now thinking it may be a MAC OS update that is causing the problem. (I did them both at about the same time). When you asked about AC 24 I went to an old project done in AC24 to see if the plotter worked with it and it gave me the same response that I got in AC25.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
