Inglewood
Use Line tool with drafting drawing
How can i draw Line tool by pick the line that i have link dwg in project?
I need to draw (Draft ) every single line by my self or every cure?
Thank you so much for your help.
1 Solution
If you have placed a drawing, then it will be one single element.
However, if you want the individual lines, you can 'explode' the drawing.
Or Edit menu > Reshape > Explode into Current View.
Go to post
4 Replies 4
I am not sure from your post what you are trying to do.
I suggest if English is not your native language, type the question in your language and use Google Translate or similar to translate it.
Only post the English translation here in the forum.
Also screen shot images can be a great way to explain what you are trying to do as well.
Archicad is not meant as at 2D drafting program.
You should be modelling with 3D elements (walls, slabs, etc.) and the 2D drawing is a by-product of the 3D model.
Inglewood
Apologize for my english.
1. I insert dwg drawing to project to draft 2D line for create morph (Image1)
1.1.
2. I try to use Line command for automatic select from reference drawing
. 2.2.
 I would like to know how to select automatic pick line on reference drawing that i insert to project.
Inglewood
Thank you.
