What is the difference between the Figure & Drawing tools?
Why are there two tools that are so similar?
Which tool would be best for me to bring in PDFs of architectural drawings so I can draw minor changes over them and then make a print of the original PDF showing the minor changes that I've made?
32 Replies 32
Yes, it is true. NO PDF with Figure Tool under Windows.
I never knew this is possible in Mac. But never missed it.
I guess if you don't know you could have something then you are not missing it that much.
Steve Jepson
johncassel wrote:
...Which tool would be best for me to bring in PDFs of architectural drawings so I can draw minor changes over them and then make a print of the original PDF showing the minor changes that I've made?
http://www.autodwg.com/pdf-to-dwg-converter/?gclid=CIH2n9GIzKYCFQQFbAodUnHtHA
Hi!
I don't know if someone has mentioned this before, but one more difference between drawing and figure is that a drawing can't be saved with a module (hotlink) while a figure can.
Andreas Åkerlund, Arkitekt SAR
Arkitekthuset Jönköping AB
ArchiCAD 5 to 25
Windows 10 64 bit
Intel i9 7920x @ 2.9 GHz, 64 GB RAM
