2024-01-23
12:59 AM
2024-12-30
05:44 PM
Molinda Prey
2024-01-23 01:31 AM
If you are not deliberately using a black background, then the first thing I would try is to restart your machine.
2024-01-23 03:50 AM
Not some macOS darkmode setting / interaction? Given that your contours are all white, it is almost as if the hardware accelerated window is having it's colours inverted.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2024-01-23 04:25 AM
I don’t know. That’s never happened to me. Does being a copy/paste from another archicad document have anything to do with it?
2024-01-23 04:38 AM
It shouldn't do.
Is the floor plan view background black as well?
2024-01-23 04:41 AM
Nope
2024-01-23 04:43 AM
Are other elevations or sections black?
2024-01-23 04:44 AM
Yes, also the sections. The plans and 3D are both fine
2024-01-23 04:50 AM - edited 2024-01-23 04:51 AM
I always thought that plans, elevations and sections use the same background (3D is different).
I have never seen them different to each other.
Check the background colour and maybe change it to something else and then change it back to white (I personally use a very pale green - easier on the eye and I can still see white lines as white colour).
2024-01-23 05:09 AM
Perfect. I’ll tell you if it works. Thank you
