Where is Cel Renderer in AC23
derekjackson
Hi, we've just upgraded from AC21 to AC23. We used to use CineRender's Cel Renderer effect all the time, but it doesn't seem to be in AC23's render panel - as far as I can see?
Please tell me it's just somewhere else in the panel? Or have they got rid of it? I really hope not. The Sketch renderer doesn't come anywhere close for quality of linework, and I've never been able to get the Cel Render shader to work correctly on objects 😞
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Erwin Edel
I spoke too soon. It is not available when you use the Physical Renderer.
If you untick this, the option is there.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
4 REPLIES 4
Erwin Edel
I just had a look, it is missing for me as well on AC23 7000 NED Full. If you look at the help, it should be there...
https://help.graphisoft.com/AC/23/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC23_Help%2F132_CineRenderDeta...
www.leloup.nl
Windows 10 Pro
Erwin Edel
www.leloup.nl
Windows 10 Pro
derekjackson
Thanks! Kind of frustrating that it disappears entirely. At least when items are just greyed, you have an idea of what's possible. With it gone entirely, many users wouldn't even know it's an option!
AC19 / 21 / 23 / 27
I agree.
To be sure I just started ticking and unticking things.
www.leloup.nl
Windows 10 Pro
