Window ID Text and Marker
mukster
Have problem with window ID 101 whenever I join the wall it will change it text and id direction it have to be like other windows such as 102 103 any thought on this how to fix it?
ā€ƒ
ā€ƒ
Jeff Thompson
I have one guess that I can share with you.  I think that the 101 window wall is not 100% straight or in the same alignment as the other two walls.  I'd draw a straight line using the line tool.  Then take that line and attach one end of it to the top endpoint of the wall and then go and look at the bottom point of the wall and see if the wall is in the same alignment.  I'm guessing it's not.  See my image below.  I adjusted the bottom portion of the wall just slightly and you see how the Window ID text flips.  I think this is what's happening to you.  Just a guess though.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Jeff Thompson
Project Manager
Thank you very much, that was the issue.
Setup info provided by author
