Zone label text control
A quick question (hopefully) - can anyone tell me how to insert a return into a zone name? As you will see in my screen shot, I need to move the 'Hall' in Entrance Hall to a second line. (The text displayed is a zone name).
I'm guessing I need to alter the zone stamp's script - if this is the case can anyone point me in the right direction to do this?
Thanks,
Tom
14 REPLIES 14
TomWaltz
If the Powers-That-Be will forgive a little shameless self-promotion:
My "SuperZone" object on Objects Online does exactly that, and a whole lot more.
http://objectsonline.com/customer/product.php?productid=122041&cat=0&page=
Tom Waltz
Your SuperZone works really well Thanks.
Now if you could sell a good guild about how to set up a door schedule in the interactive scheduler. As it is now I am putting parameters in the list that do not correspond to the information in the listing part of the door dialog box. Any suggestions?
Mark Gillis
architect
TomWaltz
How's this?
(the end result is already visible in the Fields area)
Tom Waltz
Tom,
Thanks, that helps. I'm working on it.
Mark G
Chazz
Any word on if SuperZone works in AC 10? There does not appear to be a way to select alternate zone identifiers in 10 making me think it would not work and Objects Online only claims AC 9 compatibility but I wanted to check with others before purchase.
Nattering nabob of negativism
TomWaltz
What do you mea "Alternate Zone Identifiers?"
I've been using it on AC10 for as long as 1 has been out without any problem.
Tom Waltz
Andy Thomson
Chazz wrote:
AThere does not appear to be a way to select alternate zone identifiers in 10
First off the zone label needs to be loaded to show up, and second, the zone stamp text is greyed-out in the settings dialogue because the zone stamp (such as superzone) must be selected from the 'options/zones' part of the interface....in 10 or 9 or 8....
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
Aussie John
/n
will work in any zone (or ID text or section name)
Not so great for schedules though
Cheers John
[/size]
Aussie wrote:
/n
To be more specific you would type ENTRANCE \nHALL to separate into two lines. The second line, however, will overlap Room No., Area, etc. if toggled on to show in the zone stamp.
Dan K
