2008-06-25
08:45 PM
- last edited
2 weeks ago
Aruzhan Ilaikova
2008-06-25 11:50 PM
2008-06-26 03:39 PM
Juha wrote:I never used Properties so the question will be really basic: so you can assign that to each individual instance of a module (like, place 2 identical modules, select one and make it 'apartment 1' and select the other one and make it 'apartment 2')?
If I understood the situation right, one solution could be linking properties (named by apartments) to the modules.
2008-06-28 10:27 PM
2008-06-29 12:31 AM
Juha wrote:Thank you very much for checking. I am starting to try to come to accept the idea of no tags or manually typed tags (like, 5000 of them) and Filemaker schedules.
I thought the properties could be assigned to linked modules, but it cannot be done
