composite wall exterior intersections
oippam
I am pretty new to Archicad and I am having an issue with exterior corners with composite materials. In the
attached image you can see the plywood peeking out at the corner. I tried looking through tutorials and this community page to figure it out. I am sure it is because I am not up to speed with correct terminology. How can I get the siding to wrap the corner. Normally it would not be an issue because most have corner boards, but this house's siding wraps the corner. Any help pointing to a tutorial would be greatly appreciated.
Thanks!
Matt
exterior corner - compositeexterior corner - composite
It will likely be to do with building material priorities. The plywood will be higher than the siding causing it to pass through.
Lee Hankins
macOS Sequoia (15.1.1)
DGSketcher
Legend
@oippam See if this setting fixes it... You need to turn it on [Tick].
oippam
Thanks Lee!
I actually was playing around with that and it did not seem to work. I tried dropping the priority of all the plywood in the list to below the siding.  What did work was applying the siding to the Fill Orientation.
