Patrick M
Ace
dimension quick tips
Anyone else have tips on the dimension tool? This one came in from a client and I thought I'd share it here to see what other efficiency tips anyone may have to add.
https://youtu.be/4Dn-RnaUD9U
11 Replies 11
jl_lt
Ace
It would be criteria based tool (you can define what it reads, so it can dimension structural elements or cabinets) and reads the model just like the section tool; but instead of generating a section it generates a string of dimensions. And as it "reads" the model like the section tool it's always updated no matter if you move or erase things, without doing further clicking
 It's not completely automatic as it would need setting it in place, but once set you can work in the model without much worry, and of course it would allow for manual input for very specific cases. You can copy it on any level, adjust level of detail, criteria...  one can just imagine
DimitriusMega
it's awesome to know those questions!! another trick that I love - that many people know of but it is not so intuitive - is to while having the dimension selected, you can press command/control on other hotspots and the dim line continues to add and grow. makes any task so much faster
