heathldesign
door dimension marker incorrect dims
could someone please explain why my door dimension marker is not showing the correct dimensions. i have set the door nominal sizes to unit size and the size is correct, i have set the dimension marker content to show unit dimensions, but the dimension marker is subtracting ½" to the height. see pics
ok, so the ½" difference seems to be a rounding issue. if my unit is set to 7'-1" it shows the same, if i change the unit to 7'-1 ½" it shows 7'-2" if i change the unit size to 7'-2" it shows 7'-2". is there some specific dimensioning resolution that the door / window tool can be set to separately from the dimension in project prefs?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
6 Replies 6
BrunoH
You set the Tolerance to 1/2" so the door dimensions are reduced by 1/2"
ArchiCad 3.43 to 28
MacOS Monterey
heathldesign
ok, but i don't see where to change that.
BrunoH
What is your cotation set set to ?
ArchiCad 3.43 to 28
MacOS Monterey
heathldesign
Nope, that's not it. i have it set to ⅛". i tried to set it to None like you have, but it didn't make a difference.
heathldesign
is there another place that these tolerances could be changed?
I see a discrepancy here in the values the Door Settings Dialog displays.
In your screenshot, the Unit Size Height is 7'-1 1/2" in the "Nominal Sizes and Tolerance" page, but in the "Content - Dimensions" page, the preview field for Opening Height dimension says 7'-1'.
In the case of the former, it is calculated by subtracting the Upper Tolerance value from the  Rough Opening Height, which is correct, I think.
In the case of the latter, it seems to subtract the Upper Tolerance value from the  Rough Opening Height twice, hence the 7'-1" value, which I believe is incorrect.
This may be a bug in the GDL script, so I will forward this to GS HQ for investigation. I tried this with the "D Marker 26" library part and that gives consistent values for the two fields so it may be a US-specific library part issue.
