door fill
dhnguyen
which option in the "model view option" do I check or uncheck to turn off the fill for the door?
please see attached image.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
This is not an MVO settings, but a setting in the Settings Dialog of the Door.
See the attachment for the setting you need to change.
dhnguyen
thank you!
DNguyen
ArchiCAD 18- 25
