door surfaces not working
Dave Brach
no mater what I do I cannot change the surfaces on this interior wood door. for instance you see in the screenshot it should be all red. any ideas?
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
David Maudlin
Dave:
A couple possibilities:
1. It is being override by a Graphic Override (GO).
2. In the Door Settings, the surfaces are being overridden. Your dialog box is missing the Model panel, so go to Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Door Tool and make the Model panel visible, then check the Door Settings to see if the surfaces are being overridden.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dave Brach
thanks David; it was indeed override surfaces turned on in the "Model" tab.
AC26 MBP OS Ventura
