drawing info on layout title
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-02-18
06:50 AM
2023-05-19
03:55 PM
Gordana Radonic
2015-02-18
06:50 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-02-18 07:02 PM
2015-02-18
07:02 PM
I do not think this is possible because there is no such AutoText entry that would return the name of the Source View of a placed Drawing.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-02-18 07:05 PM
2015-02-18
07:05 PM
Thanks. Not the answer I was hoping for
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-02-19 02:38 AM
2015-02-19
02:38 AM
You would think it would be possible as Archicad obviously knows the path where the drawing comes from (see attached image).
Out of curiosity I tried "Drawingpath" and "Drawing_path" instead of "Drawingname" in the label script but it didn't work.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-02-19 11:58 AM
2015-02-19
11:58 AM
With an extensive view list I prefer to go back to the source via the layout just to be sure I'm on the right drawing and it can be quicker than trying to navigate the tree.
If the drawing path is not available you could always make use of the view ID to "code" the view name which may help locating the relevant view?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-02-21 02:09 PM
2015-02-21
02:09 PM
When I select a Drawing in the Layout Book, right-click and select the Open Source View command, ArchiCAD takes me there.
If at this point I switch to the View Map in the Navigator, the View that is the source will be shown in Bold. Even if the View is in a folder within a close subfolder, the folders and subfolders are automatically expanded to reveal the View in bold.
If you do it this way you can always find out which View is the source even if you have hundreds of Views.
